tommivx
Anmeldedatum: 12.06.2009
BeitragVerfasst am: Fr Jun 12, 2009 21:10:21    Titel: Twin disk brake GSX 1100 G Antworten mit Zitat
I'm italian, I can't speak german...so I dont know if you are talked about this somwhere else. I'd like to improove the vx800's breake system, by using a gsx 1100 g front fork-weel-brake system. is it possible?
thanks
tom
starfly
Anmeldedatum: 16.04.2009
BeitragVerfasst am: Sa Jun 13, 2009 12:23:30    Titel: Antworten mit Zitat
I think u will have to wait for someone, who has realized this change in breaking system...
We`ve got 1 or 2 Members with changed Forkes...
ingodererste
Anmeldedatum: 11.05.2009
BeitragVerfasst am: Sa Jun 13, 2009 21:56:38    Titel: Antworten mit Zitat
Hi!
If it's your only aim to improve the break system you can use the fork from a CBR1000, too. The description of the change you can find here:
http://www.geocities.com/leuzi3/
Cheers, Ingo
Viele Grüße,
Ingo
tommivx
BeitragVerfasst am: So Jun 14, 2009 17:04:56    Titel: Antworten mit Zitat
Hi, thanks for the link, interesting! but I'dont like to change the color of the wheel and the fork is black...
Should be cool to change the gsx 1100 g fork..any idea?the problem is found one...
Twisted Evil
StephanCDI
BeitragVerfasst am: So Jun 14, 2009 18:02:23    Titel: Antworten mit Zitat
Well, what's the problem by painting the new wheel in the colour of your favour? Think that would be the lower hurdle than finding the one and special fork in your preferred colouring. Wink
Hans Friedrich
Anmeldedatum: 14.10.2006
BeitragVerfasst am: So Jun 14, 2009 20:35:25    Titel: Antworten mit Zitat
The diameter of die VX-800-fork is different to the diameter of the GSX-1100-G fork. This means, that you have change the Topbridge and the Stearing Stem too. Take a look at the Frontframe of the two Bikes, if the height is the same and also the bearings, you will have the best-braking-VX ever seen!
P.S.: Sorry for my english, i hope you're able to tranlate it into your own language.
tommivx
BeitragVerfasst am: Mo Jun 15, 2009 14:04:54    Titel: Antworten mit Zitat
are you sure?
I dont'find the mesures... could you find the fork diameter of vx and gsx? I see many german's sites...
thanks so much.
Razz
Hans Friedrich
BeitragVerfasst am: Mo Jun 15, 2009 15:11:28    Titel: Antworten mit Zitat
VX 800: 41 mm
GSX 1100 G: 43 mm
tommivx
BeitragVerfasst am: Mo Jun 15, 2009 15:48:28    Titel: Antworten mit Zitat
mh...
so, I found a gsx's fork at 300 euros.. but what's the diameter of the steering? are u sure that's different?
BeitragVerfasst am: Mo Jun 15, 2009 16:09:21    Titel: Antworten mit Zitat
Yes. Look at the last topic from Hans Friedrich. You have to change the complete fork! And You need also the front master zylinder (breake) from the gsx, for two disks.
tommivx
BeitragVerfasst am: Mo Jun 15, 2009 23:30:30    Titel: Antworten mit Zitat
cool! your vx is cool! but the front wheel isnt a 18"...so is not regular!? it's 17"? from how does it come for?
tommivx
BeitragVerfasst am: Mi Jun 17, 2009 11:25:08    Titel: Antworten mit Zitat
I've foud this one...
is it right?
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=350174371100&ih=022&category=89466&_trksid=p4340.m7&_trkparms=algo%3DLVI%26its%3DI%252BC%252BS%252BIA%26itu%3DUCI%252BUS-BWR%26otn%3D3%26ps%3D57
tommivx
BeitragVerfasst am: Mi Feb 29, 2012 22:17:20    Titel: Here the GSXG double disk and fork Antworten mit Zitat
http://vxdefrance.xooit.fr/t1042-Modif-train-avant.htm?start=15
http://img74.xooimage.com/views/3/7/0/imag0057-320e95d.jpg/
BeitragVerfasst am: Do März 01, 2012 00:40:08    Titel: Antworten mit Zitat
Ciao Tom,
molto bello Smile
Spero che ci vedremo a Goslar.
Frank
tommivx
BeitragVerfasst am: Sa März 03, 2012 13:41:52    Titel: Antworten mit Zitat
Here many others pics.
The VX still not ride because of the brake system...(I need to fix the caliper's pistons)
Anyway I hope that will be easy to handle and not too heavy...
http://vxdefrance.xooit.fr/t1042-Modif-train-avant.htm?start=30#p11800
tommivx
BeitragVerfasst am: Fr März 16, 2012 16:19:50    Titel: Antworten mit Zitat
Finally:
a vx 800 with gsxg's fork and double disk:-)
http://vxdefrance.xooit.fr/t1042-Modif-train-avant.htm?start=30#p11834
Shocked Shocked Shocked Shocked
