tommivx VX-Rookie
Anmeldedatum: 12.06.2009 Beiträge: 9
Verfasst am: Fr Jun 12, 2009 21:10:21 Titel: Twin disk brake GSX 1100 G |
I'm italian, I can't speak german...so I dont know if you are talked about this somwhere else. I'd like to improove the vx800's breake system, by using a gsx 1100 g front fork-weel-brake system. is it possible?
thanks
tom |
starfly VX-Geselle
Verfasst am: Sa Jun 13, 2009 12:23:30 Titel: |
I think u will have to wait for someone, who has realized this change in breaking system...
We`ve got 1 or 2 Members with changed Forkes... |
ingodererste VX-Geselle
tommivx VX-Rookie
Verfasst am: So Jun 14, 2009 17:04:56 Titel: |
Hi, thanks for the link, interesting! but I'dont like to change the color of the wheel and the fork is black...
Should be cool to change the gsx 1100 g fork..any idea?the problem is found one...
StephanCDI Gast
Verfasst am: So Jun 14, 2009 18:02:23 Titel: |
Well, what's the problem by painting the new wheel in the colour of your favour? Think that would be the lower hurdle than finding the one and special fork in your preferred colouring. |
Hans Friedrich VX-Geselle
Verfasst am: So Jun 14, 2009 20:35:25 Titel: |
The diameter of die VX-800-fork is different to the diameter of the GSX-1100-G fork. This means, that you have change the Topbridge and the Stearing Stem too. Take a look at the Frontframe of the two Bikes, if the height is the same and also the bearings, you will have the best-braking-VX ever seen!
P.S.: Sorry for my english, i hope you're able to tranlate it into your own language. |
tommivx VX-Rookie
Verfasst am: Mo Jun 15, 2009 14:04:54 Titel: |
are you sure?
I dont'find the mesures... could you find the fork diameter of vx and gsx? I see many german's sites...
thanks so much.
Verfasst am: Mo Jun 15, 2009 15:11:28 Titel: |
VX 800: 41 mm
GSX 1100 G: 43 mm
H.F. |
tommivx VX-Rookie
Verfasst am: Mo Jun 15, 2009 15:48:28 Titel: |
mh...
so, I found a gsx's fork at 300 euros.. but what's the diameter of the steering? are u sure that's different? |
Anmeldedatum: 01.03.2003 Beiträge: 1298 Wohnort: Neiße-Malxetal
Verfasst am: Mo Jun 15, 2009 16:09:21 Titel: |
Yes. Look at the last topic from Hans Friedrich. You have to change the complete fork! And You need also the front master zylinder (breake) from the gsx, for two disks. _________________ Beste Grüße. Joerg mit der SilberVX.
tommivx VX-Rookie
Verfasst am: Mo Jun 15, 2009 23:30:30 Titel: |
cool! your vx is cool! but the front wheel isnt a 18"...so is not regular!? it's 17"? from how does it come for? |
tommivx VX-Rookie
tommivx VX-Rookie
Anmeldedatum: 31.03.2003 Beiträge: 1511 Wohnort: 311xx
Verfasst am: Do März 01, 2012 00:40:08 Titel: |
Ciao Tom,
molto bello
Spero che ci vedremo a Goslar.
Frank |
tommivx VX-Rookie
tommivx VX-Rookie
